A-Series SPL WATERHOUSING for Nikon D300S - Mint Cond.
Started by photodouglas ·
  1. A-series SPL Waterhousing made to fit Nikon D300S.
    A great waterhousing for photographing surfing, sailing, kite boarding, bodyboarding, or many other shallow water activities and rated to a maximum depth of 25-30 feet.
    Housing is constructed of ultra lightweight aluminum. Sheared, formed on a sheet metal press brake and then welded solid by certified welder. All aluminum is hard anodized to protect against salt water corrosion. The water housing is then painted with industrial powder coat paint. Weight is 3 lbs with fisheye port and pistol grip.
    Features & Controls
    Control for photo/video and rec/pause.
    Shutter Speed
    Aperature
    Manual shutter release on side for emergency backup.
    Large LCD windows on top and back of housing.
    Detachable side grip.
    Latest new molded detachable pistol grip with all new custom designed two stage autofocus grip.
    Detachable flash option so you can later add a flash.
    Included Items
    Camera housing.
    Upgraded more expensive dome port to fit a standard lens, fisheye lens or wide angle lens.
    Detachable pistol grip with 2 stage autofocus.
    Custom leash.
    Neoprene port cover.
    Additional parts, tools and o-ring grease.
    Manufacturers instructions.
    Shockproof rigid foam lined travel/storage case measuring approximately 23"x18"x10"
    Housing is only 3 years old in mint condition and has had very little use.  Used only 4 or 5 times max.  Absolutely no blemishes, scratches, dings, floods or the like.  Purchased brand new from SPL and paid about $1,900 for everything with the extra options.  A great deal at $1,095.
    Contact hodgkins.doug@gmail.com
