Equivalent of Premiere's Channel Mixer in Final Cut Pro X
Started by rgilkes ·
  1. Hi everyone,
    Long time Premiere Pro user here. I'm giving FCPX a try because performance of Premiere Pro on my Mac has never been good and I'm hearing FCPX is far better.
    When I'm grading my footage, I like to the "Channel Mixer" tool in Premiere to make adjustments to the individual color channels. Does anyone know if there is an equivalent tool in FCPX?
    Thanks!
  2. 16 minutes ago, rgilkes said:
    Hi everyone,
    Thanks!
    https://support.apple.com/en-gb/guide/final-cut-pro/verf87ca7b62/mac
    The idea of using a channel mixer to manipulate colours usually produces fake colours. I have seen a number of tutorials on this where the operator wanted to rebalance the RGB channels to make it look they were all the same. That is not a good idea you are in water blue will be in most cases the dominant colour and this is fine.
    Better to use Hue curves to correct cast or to adjust skew in the colour or saturation then altering the whole thing
    Thanks. I don't use the channel mixer for primary correction, I use curves for this, but the channel mixer is a great secondary tool for fine adjustment pushing or pulling from a channel.
    There will be for sure a plug in but the standard tools are board, wheels, curve and hue you can get it all done with that
  5. Here's a free 3D party channel mixer plug-in for FCPX :
    Alex4D Channel Mixer: http://www.alex4d.com/free1
    You'll find it in Effects > Stylize Plugins > Channel Mixer – Combines colour values from red, green, blue and alpha.
    and like of these plugins, it has its own installer
    cheers
    b
    Edited by ben gazzal
  6. I Don’t ever use tools like that
    Even in the YouTube video you can see it improves nothing and makes the clip look coarse
    Thanks, will check it out
