Float arms for mdx-7100
Started by SharkGuy243 ·
  1. I'm looking for some tips for float arms with an mdx-7100 setup. I'll be using the fisheye dome and two inon z-330's.
  2. I would recommend weighing your system in water hanging it from a luggage scale.  The INON strobes are 48gr negative each underwater.  http://www.inon.jp/products/armsystem/weight_table.html
    Add up the weight of the housing underwater, clamps and strobes - then purchase arms with buoyancy less than or equal to the total underwater weight.
  3. Thanks for the reply, I'll do that!
  4. Good advice from Chris.
    I’d suggest too adding Stix floats to non-float arms. I’ve found Stix effective, light weight and inexpensive. I’ve had mine for about 10 years on ULCS arms and they’ve been great.
