Nauticam GH5 troubles w/ switching from MF to AFC/AFS
Started by ladiver33 ·
  1. Hi! I own a GH5 camera with the Nauticam housing. Having intermittent issues switching from Manual Focus to either Auto Focus C/S modes. Will have no problems or issues for a few days ina row, but 2 out of every 10 dives, once I switch to manual (w/ the camera in the housing) -  I can not switch out of it (unless I open up the camera, spin the dial myself and seal the housing back up).  Obviously far from ideal solution. It's difficult to replicate when the camera/housing are dry and topside. It seems to primarily happen in the water.  Never any issues with switching back and forth from AFC to AFS and vice versa. Just switching from MF. If I had to describe it, I would say you can can sort of "feel" that the latch or lever, is just a bit off the dial. Taking a look inside - everything looks in place, appears to be fully functioning etc.
    Curious if anyone had any similar experiences or has a bit of advice (maybe I am missing something super obvious?) before I send it off to be serviced.
    Any/all insight super appreciated! Thanks!
    Edited by ladiver33 — spelling
  2. Locate this spring and with a pencil or similar ensure that it is correctly in position as it may dislodge
    Subscribe my blog http://interceptor121.com
  3. I had the problem twice. Once, the the housing pin was slightly off center. The above will work. Test, before getting in the water. The second time, the camera was not seating well in the housing. This can cause all types of problems, but a button/lever not working is common.
    Good luck!
    Good luck!
    Bit embarrassing but after a quick call w/ Backscatter, we went through a few options. At the very end of the call they thankfully asked "Did you check to see if your camera or tray is loose in the housing?". Low and behold it was. Such a "duh" moment. Super appreciate the reply and thank you Interceptor21 for the incredibly helpful spring photo. Spring is thankfully okay!
