Olympus EPL7 housing - Port solution?
Started by snoopylaups ·
  1. I have PT EP 12 housing for my Olympus E-PL 7 comes with standard port fit the kit lens. Now i decided to upgrade my lens with Marco 60mm and Wide angle 9-18mm, anyone could let me know which ports are suitable??
    Thanks!
  2. There are Ports from Zen Underwater: 9-18 - https://www.zenunderwater.com/collections/pt-epxx-ports/products/wa-100-ep
    end for the 60: (Macro Port for th 45) ZEN FP-100-EP + Extension Ring ER-EP-25
    There are also Ports from AOi but there i do not know the Model Numbers.
    Forgotten, for Macro you can also use the original Olympus Port of the PT-EP10 Housing (for E-PL5). Where you can also use the 12-50.
    I use the Zen WA-100-EP for a while and i am really happy with it. One Problem is, that the housing is not created to regular change the Port. I solve the Problem with a Little luck and a used cheap 2. Housing.
    Edited by wedge
