Pelican Protector Case 1620 with padded dividers (Black)
Started by mr.reznovich ·
  1. Best case to protect any equipment, watertight, crushproof and dustproof. It has a lifetime warranty from Pelican. Comes with original padded dividers, that can easily be removed is needed.
    Its internal space is 54.6 x 41.7 x 31.9 cm. The external dimensions are 62.9 x 49.7 x 35.3 cm.
    Tough one to let go as it is an amazing case, unfortunately it doesn’t fit my travel needs anymore, hence I’m selling it. Originally purchased in April 2019 and since then it was only used on 4 overseas trips. It’s in amazing conditions, only a few unavoidable scuffs and marks caused by air travel.
    Here’s the full specs:
    • 4 level Pick N Pluck™ with convoluted lid foam
    • Strong polyurethane wheels with stainless steel bearings
    • Watertight, crushproof, and dustproof
    • Open cell core with solid wall design - strong, light weight
    • Retractable extension handle
    • Fold down handles
    • Easy open Double Throw latches
    • Stainless steel hardware and padlock protectors
    • Automatic Pressure Equalization Valve - balances interior pressure, keeps water out
    • O-ring seal
    400 USD ONO
    Item location is Cairns, Australia. Can ship worldwide at buyers expense.
