Kenko 1.4 TC plus WA lens combinations
Started by TimG ·
  1. There's been some discussion of late of various combinations of lenses with a Kenko 1.4TC: what works, what doesn't.
    I've got  both the Kenko 1.4TC DG and DGX models, a Nikon D500, a Z6, the Tokina 10-17 and the Nikkor 8-15. I thought Wetpixelers might find it useful to see the results of the various combinations.
    What works is in bold.
    D500 (DX)
    D500 + Kenko Telepro Plus 300 DG + Tokina 10-17: AF works; no vignetting at any focal length
    D500 + Kenko Telepro Plus 300 DGX + Tokina 10-17: AF works; no vignetting at any focal length
    D500 + Kenko Telepro Plus 300 DG + Nikkor 8-15: Err message. No AF; no vignetting at any focal length
    D500 + Kenko Telepro Plus 300 DGX + Nikkor 8-15: AF works; no vignetting at any focal length
    Nikon Z6 (and, presumably Z7) with firmware 3.0
    Z6 + FTZ + Kenko Telepro Plus 300 DG + Nikkor 8-15: AF works; vignettes with hood attached after 11
    Z6 + FTZ + Kenko Telepro Plus 300 DGX + Nikkor 8-15: No AF; No aperture readout; vignettes with hood attached after 11
    Z6 + FTZ + Kenko Telepro Plus 300 DG + Tokina 10-17 : No AF; aperture read out; vignettes with hood attached after 11
    Z6 + FTZ + Kenko Telepro Plus 300 DGX + Tokina 10-17 : No AF; No aperture read out; vignettes with hood attached after 11
    Conclusion
    a. If you want to use the Kenko with a Tokina 10-17 on a D500 no problem with the DG or DGX model
    b. If you want to use the Kenko with a Nikkor 8-15 on a D500, you need the DGX model
    c. If you want to use the Kenko with a Nikkor 8-15 on a Z6/Z7 you need the DG model
    d. Forget trying to use either the Kenko DG or DGX with a Tokina 10-17 on the Z6/Z7 (well why would you anyway)
    I don't have the Kenko HD model so can't comment on that but perhaps if someone has, they could add the data for that.
    Hope this helps, guys
    Tim
    Edited by TimG
  2. Nikon D800 (FX):
    Kenko Telepro Plus 300 DGX  + Nikkor 8-15, AF works (only used at 15mm, no vignetting)
  3. Interesting, Robin. So the DGX works with the D800 and D500 but not the Z6.
  4. Thank you for sharing Tim
    My pleasure. Confusing stuff!
  6. For canon, on a Canon 70d the DGX 1,4 works with 10-17mm.  Altough macro, it will work with a 100mm f2.8 USM macro (not the L variant), but you have to disable back or frontfocus correction or the camera wont react.
