Underwater white balance tutorial
Started by Aquatic Images ·
  1. Hi Divers
    Just wanted to share with you a tutorial I did recently in regards to white balancing your camera underwater. Any feedback appreciated, thanks for checking it out!
  2. Hi Andy, a very helpful tutorial - many thanks. A quick question, you mention that the Olympus TG-6 needs a red filter (which I have), should I do the custom white balance with the filter on the housing or should I remove the filter to do the white balance and then put the filter back on? It's been incredibly difficult to find the answer to this question anywhere online.
    Chris Greaves
  3. Hi Chris
    Definitely do a custom white balance with the red filter on for the most accurate results possible with your camera. But if you shoot anything with video lights, make sure to remove the red filter and use either automatic white balance or do a custom white balance with the lights on.
    Good luck!
  4. Hi Andy
    Many thanks for the advice, I will give it a go next weekend.
    Best regards
    Chris
