Hot spot with DS125
When I use the aiming light on my Ikelite DS125 strobe I can see a bright spot where the light is shining in the pic. Is there a setting I can change to remove it?
I did a search and couldn't find the answer.
Started by underexposed ·
Speeding up your shutter will eliminate the aiming light from your picture. 1/250 or so should suffice.
Or you could not direct your strobes directly at the subject, but rather move them outward so the beam misses the subject but still lights it up enough to see through the viewfinder. Don't get caught in the trap of using your strobe's aiming lights to position your strobes directly on the subject.
Joe
The only time it's an issue is at night. I use the aiming light as a dive light. This way I know what the camera is looking at...or I'm just to lazy to hold both...![]()
If you are shooting at night anyway, so there is no ambient exposure you are trying to get, then Don Hughes' idea is the right way to go.
Since you are shooting a pure flash exposure, all that matters is aperture, and stobe output, that determines the exposure you want. The shutter and aperture, determine the "ambient" exposure, from the modeling light. So, pick the fastest shutter speed you can use, and still get the strobe to sync.
Are you using the lowest ISO setting, as well? That will reduce ambient exposure, as long as you have enough bang in the strobe(s), to get a good exposure.
Don
