Olympus OM-D- M1 shutter Dial
Started by dovella ·
  1. I have the problem on my camera ( and also my buddy ), but I wonder if in Mark 2 this issue is solved ?
    I check outside of the housing , so it is not huasing issue.
  2. What is the problem?
    The dial is inconsistent, and sometimes difficult to change shutter speed, in the housing and also out of it.
    I wonder if this phnomena was solved in newer versions
  4. Hmmm.  That is definitely not normal. I have the E-M1 mk II (and before that a E-M5) and that has not occurred with either of mine. I would try to have it serviced.
  5. Thank you for the answer tropobo
