Help deciding between two Wet Wide Angle Lenses
Started by Dann-Oh ·
  1. Hello,
    I am trying to decide between two different wide angle lenses 1) BlueWater WA-110 and 2) Dyron Super Wide Angle Lens.  These lenses will be used on my Sony RX100Va inside a Fantasea FRX100VA housing (67mm from threads). Ive listed some of the specs below, what are your thoughts.  The used prices are within my price range.
    1)  BlueWater WA-110 specs
    FOV: 110 deg
    Weight: 575 g
    Price about $260 used, $450 new
    2)  Dyron Super Wide Angle Lens specs
    FOV: 140 deg
    weight: 850 g
    Price about $300 used, $500 new
  2. Go for the wider one.
  3. If you're not fixed on those 2 only, make sure to check out AOI / Fantasea UWL-09. I think it has better quality build and glass than Bluewater and Dyron, and you can use it with RX100 III-Va with almost no vignetting and with full zoom through capability.
