Hi all,
Due to not using this setup since a couple of years, I am selling the following:
- Nauticam NA5D3 housing including vacuum system
- Nauticam 8.5" dome port (for 16-35mm lens with extension rings, see below)
- Zen Optics 4" dome port (for Canon 8-15mm lens)
- Nauticam macro port
- Extension rings (50 and 30mm) voor macro/16-35mm lens
- Nauticam flash unit for inside the housing to fire strobes optically
Inon 45 degree viewfinder, exchangeable with regular nauticam viewfinder
- Extra O-rings
- Gear rings voor Canon 16-35mm lens and Canon 8-15mm lens
Underwater tripod by XIT404 including 3 legs and clamps
- Light & Motion Sola 4000 video light (including filter/ball mount)
Small Ikelite strobe (free for anyone whoever buys the housing)
Would like to get €2000 for everything, excluding the Sola4000 light, which would be €500 euro. Shipping is for buyer (from The Netherlands). As said, the unit hasn't been used in a while. It has been used a lot in the past where I was doing research on manta rays in Mozambique, but was always handled carefully and always rinsed with fresh water after dives. It does have regular signs of use (scuffs etc) on the housing, but otherwise works fine. Dome port has several light scratches on it but nothing that could be seen in photos. It could use a service as it hasn't been used in a while, but I set up the housing and pulled it vacuum and it holds fine, so there shouldn't be any issues with that.
If you want any loose items, we can work something out, just send me a message. Same for more photos.
