S6 and Nikonos 5 pin connections
would anyone know if you can connect a Nikonos 5 pin strobe (such as a z220) to an S6 housing socket?
situation would be a housing that has one (or 2)S6 connections but to which you would like to connect a z220 or other Nikonos 5 pin connection type strobe everyonce in a while (obviously without any type of ttl support at that point on a dslr).
if so do you need an adapter or a special connection cable?
any input would be helpful
thanks /paul
