Recsea maintenance
Started by MARINPLONGEE ·
Recsea maintenance
  1. Hi,
    I 'm looking for a company that makes maintenance (change o'rings, check and test) for Recsea Housing (for Canon S95) ?
    Any idea ? An email adress ?
    Matthieu
  2. Moved to Photo Gear & Equipment - more likely to be seen by others here.
    I assume you want to overhaul and replace all the control o-rings, I would suggest contacting one of the US retailers perhaps Reef Photo in Florida to see if they are able to service and/or obtain the required parts.  Being an aluminium housing it is likely to be possible to service it.
    You could also contact the manufacturer to see if they can supply a service kit - the website actually suggests you contact them:  https://recsea.com/index.html
  3. Thanks for moving my post, I'm beginner on this forum...!
