Nauticam NAC200 Underwater Housing for Canon C200 cinema camera
Started by marktipple ·
  1. Lightly used Nauticam NAC200 underwater housing for a Canon C200 cinema camera, bought for two shoots that were shut down due to Covid. Selling as this is surplus to current needs. Comes with SDI and HDMI bulkhead for external feed, vacuum pump, sleds, 180mm glass dome port, 20mm & 60mm extension rings. The lens is a Canon EF 18-55mm lens with both focus and zoom rings. Also an additional ball mount and clamp for the external monitor housing and two ball mounts on the grips.
    External monitor is a SmallHD 502 Bright in a Nauticam housing, with short SDI cable to connect to the SDI bulkhead on the housing. Can be used with the SmallHD housing or without, with the C200’s built-in EVF for monitoring.
    Included is a 45 meter SDI surface cable for sending a video feed to the surface or beach, and additional SDI bulkhead for the SmallHD monitor housing.
    The housing features large control knobs for focus and zoom also marking disks for lens position or focus information. Also has the Nauticam Vacuum Check and Leak Detection electronics and vacuum valve for pressurising, reading through a large multi-color LED on the rear of the housing as to the watertightness of the system. Red means bad, Blue means good.
    One of the smallest dive housings to offer DCI 4k / 60p Raw footage, added to Canon colour science and autofocus can be used for both topside and underwater. The last shoot was topside with surfers, solid as a rock -
    With the N120 port system almost any lens can be used inside, with the corresponding focus and zoom rings. PL lens systems can also be adapted.
    Worldwide postage can be arranged
    Retail is approx $23,500
    $_20.JPG119004061_865119768089_35316154474757537
  2. Sold.
