Nauticam NAC200 Underwater Housing for Canon C200 cinema camera
Started by marktipple ·
  1. Lightly used Nauticam NAC200 underwater housing for a Canon C200 cinema camera, bought for two shoots that were shut down due to Covid. Used under 20 times. Selling as this is surplus to current needs.
    Comes with SDI and HDMI bulkhead for external feed, vacuum pump, sleds, 180mm glass dome port, 20mm & 60mm extension rings. The lens is a Canon EF 18-55mm lens with both focus and zoom rings. Also has an additional ball mount and clamp for the external monitor housing and two ball mounts on the grips.
    External monitor is a SmallHD 502 Bright in a Nauticam housing, with short SDI cable to connect to the SDI bulkhead on the housing. Can be used with the SmallHD housing or without, with the C200’s built-in EVF for monitoring.
    Included is a 45 meter SDI surface cable for sending a video feed to the surface or beach, and additional SDI bulkhead for the SmallHD monitor housing.
    The housing features large control knobs for focus and zoom also marking disks for lens position or focus information. Also has the Nauticam Vacuum Check and Leak Detection electronics and vacuum valve for pressurising, reading through a large multi-color LED on the rear of the housing as to the watertightness of the system. Red means bad, Blue means good.
    One of the smallest dive housings to offer DCI 4k / 60p Raw footage, added to Canon colour science and autofocus can be used for both topside and underwater. The last shoot was topside with surfers, solid as a rock, highlight clip below.
    With the N120 port system almost any lens can be used inside, with the corresponding focus and zoom rings. PL lens systems can also be adapted.
    Housing is in Adelaide, South Australia post/zip code 5169, worldwide postage can be arranged.
    Asking AUD $17,000 for the full kit, or AUD $13,000 for the kit minus external monitor kit.
    Retail is approx AUD $23,500 for the full kit, and AUD $18,500 minus external monitor kit
    Email enquiries are best, mark@marktipple.com
    119004061_865119768089_35316154474757537
    118846397_865121050519_72590086271863022118938578_865119633359_33275933983747371119099986_865119658309_62890907487947022118943487_865119608409_56105232198926502119040885_865119688249_13179167438081392118842119_865119743139_89201324344562127118826832_865119713199_18939652722081062118884686_865119822979_73984925640030511119022443_865119847929_59109752522028813
  2. Sold.
  3. Available again, buyer went awol. The lens zoom and focus gears are not available.
