Nuevas lentes extensible
Started by Pedro ·
  1. En camaras sin espejo marco completo, se han de desarrollado nuevas lentes extensibles como:
    -          Nikon 24-50 mm
    -          Sony 28-60 mm
    Alguien sabe si estas lentes son compatibles con lentes humedas como la Nauticam WWL-1.
    -          Nikon 24-50 mm
    -          Sony 28-60 mm
    Google Transalated:
    In full frame mirrorless cameras, new extendable lenses have been developed such as:
    - Nikon 24-50 mm
    - Sony 28-60 mm
    Does anyone know if these lenses are compatible with wet lenses like the Nauticam WWL-1.
    The WWL-1 port chart is here:  https://drive.google.com/file/d/1Cyk7BxeB8sVcmnoG03Up4yilm0i62xFg/view
    these lenses are not listed as yet -   the WWL-1 requires a 28mm equivalent lens at the wide end so the Sony lens may work.   The Nikon would need to zoom to 28mm to stop vignetting and may also work.  You would need a flat port of the right size available which placed the front element up close to the port glass - Nauticam don't list these lenses so you would need to work out the appropriate port yourself if you wanted to test the setup.
    The WWL-1 is mainly specified with compact - through to APS-C system lenses the only full frame Nauticam list is the Sony 28mm f2.  I'm not sure why this is But I expect they would list more lenses if they worked for full frame cameras.
