Nikon housing accomodating tilting lcd monitor
Started by scottleslie ·
  1. Does anyone make a housing where you can actually tilt the LCD on the camera so you can see the image from directly above (like an old fashioned optical vertical finder)? This would be so I can use it on a floating platform in shallow water with my arms extending down vertically into the water, or nearly so. Thanks for any suggestions!
  2. Never seen such a housing.
    The best option for this scenario would be to connect an external monitor to the camera, and use this to replace the rear LCD view.
    This external monitor would enable a full remote control operation too ...
  3. Going back into the mists of time (2000), I had a Nikon Coolpix 5000 and a Subal housing for it. And you could do exactly that!
