how to tell what ports will fit
Started by Dann-Oh ·
  1. Hey all,
    I just ordered the AOI UH-EPL10 (AOI's housing for the Olympus E-PL10 from Backscatter) I am wondering how to tell what ports are compatible with the housing?  I've been quotes a 4" (DPL-06) dome port but for split shots I'm told bigger is better, but AOI doesn't seem to sell a 8in port that will fit my housing.  Any ideas on how to find a different port to fit my housing?
  2. Hey Dann-Oh
    Sorry I can't help on the Olympus dome but no question you need the biggest dome possible for splits (under/overs).
    You would really struggle with a 4" dome and the motion of the water. I'd suggest 8" is the minimum - and even bigger is even better (and even horribly more expensive)
  3. Dann-Oh,
    Your best bet is to contact Backscatter, they are always very helpful.  I think that the PEN ports are compatible, but not 100% sure.
  4. The housing appears to use the same ports as AOI make for the Olympus PEN mount housings.  AOI make an 8" dome the DLP-07/08 but in the OM-D mount.  They also make an adapter : https://www.aoi-uw.com/products/aoi-ad-lp-01.html
    So you should be able to mount the DLP-07/08 to your housing with the AD-LP-01 adapter, but working out the right extension might be a challenge. the port chart for AOI ports is here:
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiojbmXhYjtAhWFT30KHTWUAQkQFjAAegQIAhAC&url=https%3A%2F%2Fwww.aoi-uw.com%2Fmedia%2Fwysiwyg%2FAOI_Ports_Chart_for_OLYMPUS_Housings.pdf&usg=AOvVaw1WenfnUg9lE_ObeEBtsx0s
    and as they appear to use olympus focus gears should be applicable to your housing.
