Digital Photo's Bland
Started by westfax ·
  1. Digital Photo's Bland
    First few exposures on my D70 produces good pictures but very bland results. The pics are there, however the the colour, saturation and contrast is very different to what I am used to on film. I find myself shooting at exposures way out of sync to what I know works on film. (F32@1/350)
    I use the highlights setting to avoid overexposure, and this is my main criterea to judge whether I keep the pic or not. I have only shot with a 105 macro lense with an Ike 50 strobe on manual, and a S&S YS90 strobe whitch I toggle between half and full dump. The reds are orban, blues are matt and yellows are gray! Varieng the distance between the strobe and subject yeilded slight improvement but still no satisfaction.
    My question is; will changing the strobes to the type that you can vary the f stops on the unit make things better or will a "digital photography" book increase my understanding, or am I just missing the digital plot?
    Will knowledge of functions like the histogram increase my underatanding?
    I have been using the TTL function on my film camera's for exposure and now I am forced into the manual options.
    Any suggestions on how to make this learning curve quicker?
  2. Taking the picture is just part of the process. Some digitals will produce images that look fairly good "out of the camera", but a certain amount of post-processing is usually necessary for images produced by any digital camera. (The same applies to most scans of film images - even a perfect slide - out of most scanners.)
    If you're shooting JPEG, you can do a certain amount of very crude "pre-post-processing" through adjustments in the settings. There is no reason you should want to do this, however.
    As Peter noted, you definitely want to shoot RAW. The big advantage is that you can now select the exact adjustment of color temperature, saturation, and contrast and other variables later, image by image, at the time you convert the raw image to a usable image format. You can also do quite a bit with exposure as well, in effect re-rating the ISO setting, though of course any area that is completely over-exposed in any channel is probably beyond recovery. Different converters provide different options, but most of the decent ones (such as the raw converters built into Photoshop CS) have all that you will need.
    If needed, further adjustments can then be made in Photoshop.
    Robert Delfs
