FOR SALE: Zeiss, Sony, Tokina/Canon UW Lens and Nauticam Gears
Started by Marsh ·
  1. 1.  Zeiss 12mm Touit Lens-UW Modified for N85 Ports. This lens was modified partly by Zeiss and myself to be used on the N85 port system. The outer shade support system has been removed and replaced with a series of filter rings. This allows the lens to be used with the N85 4.33 and 7" dome ports. I used it with the N85 4.33 FE port with a 20mm mini extension for a more compact system. The corners were very slightly less sharp than the larger 7" dome. I seldom could see the difference and preferred the compact travel friendly use of the N85 4.33
    Zeiss designed a new outer shell for me, but I choose not to use it because I would lose the 67mm filter ring for Fluorescent photography work. I ended up turning another diver on to the modifications and he now has the Zeiss modified lens for sale.
    We both have moved on to the N120 system and no longer need the lens. This is an ultra sharp WA lens that will give astounding results in N85 ports on the Sony APS-C system without the need for a two part port system.
    The lens comes with the original equipment and can be easily returned to it's stock state with the shade system. It also has a B&W filter for protection.------$575 + 15 ship to lower 48 states.
    2. Tokina Canon 10-17 Fisheye NH Model (can be used FF) w/ Zoom Gear. This the the more expensive NH model without the shade, so it can be used full frame for a more budget set-up. It's in mint condition with mounted zoom gear------------------------------------------------$450 + 10 ship within the lower 48 states.
    3.   Sigma-Sony 16mm f1.4 E-mount lens-UW Modified for N85 Port System. This lens was modified to fit the Nauticam N85 port system. Stock, the lens is 1.5mm too wide to fit the opening. The modification involved removing the shade mount, along the rubber focusing grip so it would fit the Nauticam N85 4.33 compact port (it's a long lens and needs 50mm of extension (20+30mm mini extensions in combination) to work with the 4.33 dome. This is a super fast f1.4 and ultra sharp and fast focusing lens for video and still photography. It has extreme close focusing distances, so it's excellent for CFWA. I have moved to the N120 system and no longer need this lens. This is the only f1.4 option for the Sony APS-C system.  $325 + 15 Ship to the lower 48 states.
    4.   Sony 18-55 Kit Zoom with Nauticam Gear both in excellent condtion. Works with N85 Port 72, N85 4" Semi WA dome and N85 4.33 FE dome with a 20mm extension. This kit has better optics than the newer 16-50 lens that retracts everytime you turn the unit off, making it much easier to deal with. This is a sharp copy and I'm selling it because I've replaced it with the Zeiss 16-70.
    $185 + 10 ship to lower 48 states suing Paypal
    Please PM me if you are interested in any of these lens and gears.
    Thank you,
    Marshall
    NOTE: I will be leaving the states for the Philippines on Dec. 18 and will return on April 2nd (Filipino wife). All sales to be delivered before my return date will need to be made prior to Dec.15, 2020.  All payments must be with a confirmed Paypal account and will be shipped only to the address on that account.
    Edited by Marsh
  2. The Philippines trip has been cancelled due to COVID so we will be here in the US.  PM me if you're interested.
    Marshall
  3. PRICE REDUCTIONS:
    Zeiss 12mm Touit Lens-UW Modified for N85 Ports----------------------------$495
    Tokina Canon 10-17 Fisheye NH Model (can be used FF) w/ Zoom Gear------$395
    Sigma-Sony 16mm f1.4 E-mount lens-UW Modified for N85 Port System----$250
     Sony 18-55 Kit Zoom with Nauticam Gear --------------------------------------------$140
    Update on travel:  I'll be leaving the states for the Philippines in mid March and returning in late June.  All purchases will have to be before or after, unless you want me to hold it for you.
    Thank you,
    Marshall
  4. Tokina 10-17 Fisheye setup (Canon) SOLD!
