Hints to store and carry dome ports ?
Started by jumattil ·
  1. Hints to store and carry dome ports ?
    Hi,
    I´m newbie with housing after about 10 year Nikonos-V period.
    Is there good hints how to avoid dust getting in to dome ports ?
    It seems that plastic dome attracts dust inside it.
    Also cleaning hints of dome (inside) are welcome.
    Jussi
    :shock:
  2. StaticMaster
    Plastic in general does seem to be more attractive to dust than glass.
    I use a StaticMaster brush. Kind of pricey, but works like magic.
    I store some ports on the housings, with storage o-rings; others have back port covers from the manufacturer.
    All the best, James
  3. My ports are glass, so static and dust aren't serious problems. I occasionally clean them with lens cleaning solution and a photographer's chamois cloth. I don't know what you would use for acrylic.
    Covers for the port back opening are important for storage and travel. Also useful are front port covers - you can get them made out of neoprene, sort of like a beanie for the dome port, with "ears" - loops of shock cord - on each side to hook over something sticking out on the housing to hold it on. Keeps down avoidable scratches topside, especially when a lot of cameras are being loaded in an RIB, etc.
    Travelling, the dome port goes with the housing and laptop into Pelican case with appropriate voids made in the pick-foam. (The dome port sits over the laptop.) The neoprene beanie and back cover are both kept on the port when it's travelling the the case.
    Frogfish
