plastic boxes to 30 meters
Started by whitehead ·
  1. plastic boxes to 30 meters
    I want to "house" and take down to 30 meters a number of land flashes (SB600) at approx. 68 x 123.5 x 90mm (2.7 x 4.9 x 3.5 in.) each.
    But I need to find someway to house them - does any one know of any clear plastic "boxes" that are water proof to 30+ meters???
    Just a box that is clear and can be sealed on the surface - no need for any cables or arm fixings or anything else?
    cheers
  2. I wonder if you could do it with old used video housings, that no camera exists for any more... Should be cheap!
  3. I've seen someone who's modified a UK torch to a flash housing but only as slave.
  4. Ikelite
    Ikelite sells just what you need.
    Try part number 5710. It's about 9x12x20 cm. This is what I used to house a Vivitar 283, quite a while ago in the ancient past. There's one a bit bigger, too.
    Can't remember the depth rating, but I recall taking it to 160 fsw.
    All the best, James
