AOI UH-EM5III for Olympus OMD E-M5 Mark III
Started by turandot ·
  • 9Posts
  • 9Replies
  1. I open a new thread for the next underwater housing AOI UH-EM5III for Olympus OMD E-M5 Mark III. These are the possible specifications:
    - Port system: OM-D Mount ( extended to the Olympus OM-D system)
    - Depth Rating: 60M / 157FT.
    - Housing Body: Polycarbonate
    - Vacuum valve is built in with USB-C charging.
    - Double-layer Oring protection.
    - There is no built in flash trigger. It’ll be a separate purchase.
     ( AOI STR-003 flash trigger )
    The housing AOI UH-EM5III have the same OM-D Mount that Olympus Housing PT-EP08/11/14 series.
    For M.Zuiko 8mm PRO lens Backscatter recommended AOI DLP-07 / 08 (8 inch) without extension ring setup for best image corner sharpness and AOI DLP-01 / 02 (4 inch) + AOI 22mm Extension Ring when smallest travel size is primary requirement.
    I read the AOI Ports Chart and it's also possible to mount AOI DLP-05 / 06 (4 inch) +  AOI 22mm Extension Ring for M.Zuiko 8mm PRO lens.
    AOI Ports Chart for OLYMPUS Housings. I think is the same port as OM-D Mount we've seen in EM5III housing.
    https://www.aoi-uw.com/media/wysiwyg/AOI_Ports_Chart_for_OLYMPUS_Housings.pdf
    Edited by turandot
  2. Oh for pete's sake- I just bought an M1mkIII last week; I would have held out if I knew this was on the way :)
  3. No problem, AOI UH-EM1III for Olympus OMD E-M1 Mark III.... is on the way!
  4. Man, if that's true I'll name my first born child after you.  I'm 50 and single, but hey...
    What pressure!! :rofl:
  6. Unofficial  image AOI UH-EM5III:
    Edited by turandot
  7. It's official!! The UH-EM5iii underwater housing for the Olympus OM-D E-M5 MKIII is here!! Now it's time to wait for its specs
    We have the first official image! A new colour has been presented.
  8. AOI UH-EM5iii vs Nauticam NA-EM5iii
    AOI Dimensions:  206mm(W) x 182mm(H) x 114mm(D)
    AOI Weight in air: 1.340g (LCD lens hood and lanyard included, camera and accessories not included for the calculation of this weight)
    Nauticam Dimensions: 196mm(W) x 166mm(H) x 99mm(D)
    Nauticam Weight in air: 1.400g (Camera and accessories not included for the calculation of this weight)
  9.
    AOI UH-EM5III System Chart
    DzvUAtyg_nD2UeBAJKZWeL1TGlgRJtUYSRnm80Z9
