Subal ND3/4 + dx3 + 16-35 f4
Started by llenahan ·
  1. I have been shooting a dx2 in a Subal ND2 with a dp-230/3 dome.
    Interested in moving up to a d3x with a 16-35 f4.
    Have
    d3x
    subal nd3 with 4 mount
    subal 230 with three mount
    question:
    can the 16-35 be used with a series 3 subal mount?
    No guessing please...
  2. Is the question does the 16-35 f4 fit in the smaller type 3 dome adapted to a type 4 housing?
  3. It'll be the size of the opening on the Type 3 domeport which will be the potential problem.
    - Nikon list the maximum diameter of the 16-35 as 82.5mm.
    - According to Reef Photo, the Type 3 port is 100mm with a 93.5mm flange:
    https://reefphoto.com/blogs/faq/subal-port-mount-identification
    So should be fine. Tight fit, but fine.
    The zoom ring should be inside the housing (not the port) so that shouldn't be a problem.  Although you'll probably always have to fit the lens (with camera) through the back of the housing - not lens only through the port opening. So removing the camera to do a lens change.
    Edited by TimG
  4. Thank you for your answer.  Trying not to buy a 230/4.  Appreciate your help.
    I can understand that!
