Ikelite Manual Controller Problem?!?!
Well I had me a nice malfunction on my recent trip.
Maybe someone can help explain.
I have a D70 with dual Ike DS125's with 2 manual controllers. I tested everything topside and it was working fine.
On the first dive, I took the first photo, and then I could hear one of my strobes beeping at me. I looked over at it, and it was constantly firing.
I turned it off and on again, and tried another test shot. Same thing. It started beeping and non-stop firing.
I tried different combinations of one strobe off and one on, and ultimatley gave up, as I couldn't get either strobe to fire with the other turned off, and with both of them on I got the beeping and non stop firing.
I quadloople checked that both strobes were in TTL mode connected to the controler. I made sure that the manual controllers were actually set to a number, and not in between 2 numbers, or pointing to the clicks that aren't settings at all.
I tried both strobes in manual mode and still could get them to fire while connected to the manual controllers.
After the dive I just removed the manual controllers from the rig, and did the rest of the weeks diving with the strobes direct connected and set to 1/2 power.
I assumed that something must be wrong with my manual controllers, but what was really strange, is that my friend that was with me, who dives an identical rig, had the EXACT same problem on dive 2.
Any idea what could be wrong? I'm thinking it's got to be something I set up in my camera that is causing it.
I checked my camera settings to make sure the flash was set in normal flash mode, no red eye, no rear curtain, etc...
I checked to make sure exposure compensation was set at zero...
Not sure what else it could be...
-Jim March
