Hello
I have an olympus tg-6 with pt-059 and a sola 2500 flood
I primarily (90%) want macro footage.
Was wondering whether to add a 4,200/1,200 flood/spot as a supplemental light.
Supplemental in the sense, to add more light to the 2500 sola - so I can use lower ISO and faster shutter speeds.
My question is, can the tg-6 compensate with faster shutter speeds if I turned on the both 2,500 and 4,200 lights (total of 6,700) ?
I suppose if not, I could dim the 4,200 to 2,100 for example.
My aim is to use as bright lights as possible to yield lowest ISO and faster shutter speed - while obviously having it exposed correctly.
Technically I think I could because people use the tg-6 with strobes that are significantly brighter than 6,700 lumens. But I also know strobes also don't categorically output maximum brightness - they use TTL to meter.
Would love help from anyone with experience.
Macro subjects include as large as fish close-ups to commensal shrimp as small as half an inch.
Thank you.
