d70 shutter delay
Started by mrbubbles ·
  • 9Posts
  • 9Replies
d70 shutter delay
  1. d70 shutter delay
    I just used my d70 with inon 220 strobes for the first time. I noticed a delay between when i press the shutter, and when the camera fired. Did i have the settings wrong? I was using all manual settings for camera and strobes. Do i need to disable the preflash?
  2. I've never experienced a delay after the camera achieves focus.
    Karl
  3. d70 shutter delay
    I was shooting fast moving seals, so was the delay just the focus waiting to lock? should i just have been in C mode?
  4. That could be the delay you are experiencing. In AF-S, the camera won't fire until focus is achieved. AF-C might help with fast moving subjects....but be aware that in AF-C, the camera will shoot even if it's out of focus....would be worth trying out next time
    I've only used AF-S underwater, but many have success with AF-C.
    Karl
  5. Not sure what Housing you have, if it's the Ike, can you see the focus assist lamp coming on? If it's metal, take the back off and do a 1/2 press to check it.
    I was having a slow response with mine until I figured out that was the problem. You can turn it off in the menu.
    Rand
  6. d70 shutter delay
    I'm using a nexus housing and inon 220 strobes. My shots were all in focus, so maybe that means it was a focus lock issue, i was wonderor ing if it could have been a preflash issue, or something else
  7. I experienced the same type of problem, and switched to AF-C. Camera fired perfectly then. The delay is the focus. I haven't experienced any out of focus problems with AF-C
  8. Cudos to Ike. I was in Fiji and experience a port dome leak. E-mailed Ike and had a new port within 4 days. Saved the trip.
