dome for sony A7iii
Started by WesleyD ·
dome for sony A7iii
  1. Hello!  For those who use Sony Full Frame cameras, which size dome do you use for the 8-15mm fisheye?  Thank you so much!  I greatly appreciate it!
  2. I use the Nauticam 140mm dome port with the removable sun shade. Be aware that any port you buy needs a removable shade or the shade will vignette at the 8mm circular fish end of the lens. I also use the Zen 230mm port for split shots again with the shade blades removed.
    will depend on what housing system you are using as to what is available.  The port charts from the housing manufacturer usually give good guidance.
  4. For my Sony A7RIV in Nauticam housing I use:
    • Mostly a Nauticam 140mm dome port with removable shade; and
    • Occasionally a Subal 200mm dome with a Nauticam/Subal mount converter
