hot shoe light mount
Started by rwe ·
  • 9Posts
  • 9Replies
  1. I would like to mount my dive light to my Fantasea housing hot shoe. Is there an adapter made for this or has anyone done a DIY mount?
    Highly recommend NOT mounting anything on hotshoe.  It will get loose at the worst moment and fall off, sometimes when you don't notice.  Speaking from personal experience, I now nail down tight all lights via clamps / screws, and don't even use bayonet mounts for wide angle wet lenses.
  3. If you go with the ULCS system they will also include an "Oh $hit Leash" for your light in case it does fall off.
    My focus light is cold shoe mounted and has a lanyard and I loop that around the closest arm clamp and tighten the little bungee clip down - doesn't interfere with the clamp operation  or positioning the light and will save the light if it comes loose, plus it keeps the lanyard from floating around.
    Edited by ChrisRoss
  5. 10 hours ago, pygmy_whaleshark said:
     I ... don't even use bayonet mounts for wide angle wet lenses.
    It really depends on what kind of bayonet mount. Some (like the Nauticam) have a positive lock you must press to release them.
  6. Even with the bayonet mount I use a lanyard.  When it is moved from the port to the arm bracket I know that if I don’t have a lanyard I will drop it, and most likely on a wall dive!
    I used to use the INON bayonet mount, which also had the lock. Guess what a quick accidental twist during a strong current caused me to lose the lens once, and I only found out when I drifted too far away.   I've never found the need to constantly swap wide/ macro wet lenses on any dive, so I just screw them in now.
