WTS Sea Frogs Salted Line a6xxx housing
Started by tomunderwater ·
  1. Lightly used Sea Frogs Salted Line a6xxx housing (purchased new less than a year ago).  Never flooded.  Set up for a6400, but can easily be used on the a6000, a6100, a6300, and a6500.  Note, the a6600 will not fit in this housing.
    Asking $400 or best offer
    Includes:
    -housing https://seafrogs.com.hk/collections/a6xxx-salted-line/products/seafrogs-60m-195ft-waterproof-housing-for-sony-a6xxx-series-salted-line
    -4" flat port (glass)
    -6" dome port (acrylic) https://seafrogs.com.hk/collections/a6xxx-salted-line/products/6in-dry-dome-port-for-salted-line-series-waterproof-housing-40m-130ft
    -Vacuum pump system https://seafrogs.com.hk/products/vacuum-pump-system-vps-100
    -Zoom gear for 10-18mm Sony f/4 OSS
    -Zoom gear for Sony E 16-50mm f3.5-5.6 PZ OSS
    -Extra silicone grease and o-rings
    See specifications from the manufacturer below.
    Key Features:
    • Inbuilt leak sensor
    • Depth rate 60m/195ft
    • Port for Fiber optic cable
    • Port for vacuum test system
    • Two 1/4" -20 threaded holes
    • Interchangeable port system
    • High-quality optical viewfinder
    • Double-sided metal hinge lock
    • Multi-coated optical glass standard flat port
    • Reinforced metallic bottom plate
    Edited by tomunderwater
  2. Hi, I am interested, is it ship international? I am locate at Malaysia
  3. Hi Shinw, sorry I'm just seeing this message.  I am happy to ship this to you if you are willing to cover the shipping costs.  Please send me a direct message if interested.
    Tom
  4. Sold
