pic posts
Started by mrbubbles ·
pic posts
  1. pic posts
    yes i'm new to digital. no i'm not stupid, just helpless. i need advice on submitting pics as attachments. what specific settings ,size, resolution, or anything else i don't know how to do. Also how to send multiple pics. signed:old-guy powerless over computers
  2. As to the attachment requirements, the pictures should be saved in JPEG format, with the longest side of the shot being approximately 640 pixels. this will cause most of your shots to be around 640x480, or 480x640. Once your pictures are in this format and size, you need to adjust the "quality", or compression, of the shot so it is smaller than 75k (file size).
    When you are creating a post, on the bottom use the Choose File button to add this file. Then click on Add Attachment and you will be able to use Choose File again to add a second file.
    HTH (Hope This Helps)
