Olympus EM1MK2 rear button (video) focus and peaking
Started by andywillett ·
  1. Hi all
    Can any one help, I've set my  rear button focus (video) on my Olympus  EM1mk2  and also have set the front button to SAF.
    I can update the focus  by either button, all good so far
    However if I turn on Peaking, the peaking has to be turned on every time I use back button focus, but the peaking stays on with the front release.
    Any ideas why this is?
    Kind Regards
    Andy
    Edited by andywillett — typo
  2. It has to do most likely with the fact that all back and menu are customisable and the shutter isn't so each time you take a custom button is like you are using one function at time and you can't have both at the same time if that makes sense?
  3. Hi thank you, I guessed it was just a limitation of options
    Just checking just in case I was missing something or there was a work around i could try.
    Thank you
