but can not determine which is best for TTL hook up.
hmmmm.......
No recommendations here, just thoughts.......
Not sure if you'll be able to use a S & S or Ikelite sync cord directly attached to an Oly housing unless you convert to a mike-dive.de aftermarket bulkhead system:
http://www.mike-dive.de/
or:
http://www.camerasunderwater.co.uk/d_still...ges/mh_oly.html
I believe that the only TTL option (except for the mike-dive conversion) you may have with a Sea & Sea strobe with your rig would be in conjunction with Matthias Heinrichs' TTL Converter:
http://www.muenster.de/~matthias/blitz/oly2nikone.htm
or Digital Adapter:
http://www.muenster.de/~matthias/blitz/int...ntroduction.htm
Has anyone used either Strobe with this Oly Housing?
Which strobes in particular have you been researching? Between Ikelite and Sea & Sea, there are at least 15 strobes:
http://www.digitaldiver.net/strobes.php
There are strobe triggering options other than sync cords. For the pt-020, Ikelite has two strobes, the DS 50 and the DS 125, that offer TTL strobe control when combined with their optical TTL sensor. Inon offers TTL in conjunction with a fiber optic triggering system for their strobe models.
hth,
b
