Vacuum Pump - low cost solution
Started by Grant M ·
  1. Hi
    My Hugycheck pump failed.  I've ordered a pump to fix it but need a reliable backup solution.
    I have found that there are very capable manual pumps available for less than £5.
    One of these from ebay only requires me to cycle the pump 7 times to get to vaccuum with an empty housing. Hose not required and pump fits the valve on the housing perfectly.
    1Set Air Pump Suction Pump Manual Pumping For Vacuum Compression Bags NT | eBay
    Safe diving
    Grant
