Nauticam NA-a2020 Housing for Sony A9II/A7RIV Camera
Started by ad6339 ·
  1. Recently found out without an ear surgery I should no longer be diving so I have decided to sell my new gear I got in March of 2021 and has only been under water 5 times. Everything is in perfect condition and purchased from Reef Photo
    I have the gear for sale and the camera as separate. Firm on pricing. Contact me for more images.
    Asking: $7000 for gear and $3500 for camera and lens
    Housing items:
    1    Nauticam 70x200mm Carbon Fiber Aluminum Float Arm (Buoyancy 370g, Lifetime Warranty)
    1    Nauticam 125mm Double Ball Arm
    1    Inon Z-330 Underwater Strobe
    1    UW Technics 11075 Optical/Electrical TTL-Converter for Sony (Nauticam Housing NA-A7II, NA-A7RIII, NA-A9)
    1    Nauticam Universal Optical Fiber Cable
    3    Nauticam Standard Clamp
    1    Nauticam Mounting Ball Adapter for Inon
    1    Nauticam NA-a2020 Housing for Sony A9II/A7RIV Camera (with HDMI 2.0 support)
    1    Nauticam SFE2860-Z Zoom Gear for Sony FE 28-60 F4-5.6
    1    Nauticam N100 Flat Port 45 with Focus Knob
    1    Sony FE 28-60mm f/4-5.6 Lens
    1    Nauticam M14 Vacuum Valve II (Pushbutton Release)
    1    Nauticam M67 Bayonet Mount Converter II
    1    Nauticam Wet Wide Lens 1 (WWL-1) 130 deg. FOV with compatible 28mm Lenses
    1    Nauticam 18cm Lanyard With 2 Snap Hooks
    1     Cinebags Grouer bag
    1     Think tank roller bag
    8     Panasonic batteries with charger
    Total spent - 8283.00
    Camera / Lens
    Sony FE 24-70mm f/2.8 GM
    Sony Alpha a7R IV Mirrorless
  2. Hello!
      Do you still have this for sale? Would you consider separating it? I am interested in the camera/lenses and housing, but not the strobes/arms.
    Thanks!!
    Maggie
  3. Hi there! I am interested in selling the camera, lenses and accessories. I have already sold the housing.
  4. Hi ad6339. Im interested in the setup. How do I contact you?
  5. Remaining items for sale:
    Nauticam 70x200mm Carbon Fiber Aluminum Float Arm (Buoyancy 370g, Lifetime Warranty)    95
    Nauticam 125mm Double Ball Arm    40
    3 Nauticam Standard Clamp    95
    Nauticam Mounting Ball Adapter for Inon    25
    Nauticam 18cm Lanyard With 2 Snap Hooks    35
    Cinebags Grouper bag    140
    Think tank roller bag    300
    Inon Z-330 Underwater Strobe    540
    Nauticam Wet Wide Lens 1 (WWL-1) 130 deg. FOV with compatible 28mm Lenses    1150
  6. I'm interested in the WWL-1 and lens, if they're still available.  Sent you a PM.  Thanks.  :)
