Nikon D70, rec ISO, Shutter speed and Appiture setti. bracke
Started by john.reintjes ·
  1. Nikon D70, rec ISO, Shutter speed and Appiture setti. bracke
    I am looking for guidance or reading material books on best recommendation for the following setting for a Nikon D70, settings for ISO, APPature, shutter speed best, bracketing for white balance and the prefered white balance setting to program to eliminate excessive blue, even with flash.
    I am using a Nikonos 125 manual controler flash, any suggestions until the TTL modification is available.
  2. Peter do you think these settings also could apply to the D100? Thanks for all the great info at your site.
  3. I think most of these settings will work for the d100. The differences in functionality are slight.
