WANTED: Nauticam 10mm N120 Extension
Started by Marsh ·
  1. Looking for a  Nauticam 10mm N120 Extension.
    Marshall
  2. i may have one .
    item number Nauticam #21110 : Extension Ring 10 with screws
    pay attention, iot is not extension with Lock, but with screws. (ER with lock does not exist anyway)
    Shipping from Switzerland, worldwide.
    please MP : eric (at) colorsoftheblue (dot) com
  3. 11 hours ago, lambee01 said:
    i may have one .
    Thanks, I'm aware of the screw application. I have a custom Sony APS-C set-up using all N120 ports and extensions. Everything is shot through a 4.33 dome that I customized with a 67mm macro swing mount on it's shades.  Just purchased a Nauticam Port 60 which is about 10mm short of perfect lens placement. I wanted to get back the 25% magnification I'm losing with the dome when using my Sony 90 macro lens, but after some testing and consideration, the magnification with a 90mm macro on APS-C, along with the use of wet closeup lens is quite sufficient in terms of magnification. No sense in lugging around a second port. I'll be selling the Port 60. Thanks for the info and responding. M
  4. I no longer need this extension.
    Marsh
