14 hours ago, eyeguy said:
I tried using the camera menu to set flash sync speed menu option to "Auto-FP" but I still wasn't getting it to sync.
Hi Stewart,
By the way, did you look at the User Manual, i mentioned above? There written the details about switching to M modes in that system. If you use method of menu assigned command ("Auto FP" switches to M mode), you also recommended to set camera menu "Flash Exposure compensation" to maximum value (+3 ev). This way the Converter issues a single pulse of maximum intensity. The same effect gives the position "0" of rotary switch. Maximum intensity pulse is important for MF-1 low sensitivity input control.
Fiber optical cable must be 613-core only. This is important here, because it has transmission index few times better than previous type cables. Nauticam sells new 613-core cables #26216 and #26217, but old type Nauticam cables are also available on the market. You have to check your cable model number, to be sure that it is 613 type optical core. Also, try to connect the strobe by another cable (if you have 2 cables), because fiber optical cables sometimes have partially defected core treads inside the cover.
Also, i can check if your version #26308 board hardwire is up to date for MF-1 support. Send me a macro photo of your board. Because MF-1 is supported by that board of latest version.
