Sony microdrive
Started by underexposed ·
Sony microdrive
  1. Sony microdrive
    Does anyone have the Sony microdrive? It comes in 2 and 4 gig. When I am compairing it with other microdrives it seems to have much faster speeds. I want to know if I'm reading it wrong. The Hitachi says it has a transfer rate of 7mps and the Sony says 97.9mps...can this be right? Are they playing with the numbers? Under capacity is says 12gb, this must be a typo as it is a 2gb drive. The transfer rate I have read on a few sites though. The info below was coppied from
    http://www.sonystyle.com/is-bin/INTERSHOP....oductSKU=RHMD2G
    It does seem to have a better operating temp range then the Hitachi. I need to get something and am leaning to a compact flash but want the best performance for processing the raw files.
    Please share your thoughts...[:]q
    Specifications • Capacity: 12GB
    • Sector size: 512 Bytes
    • Interface: CF+TM Type II
    • Format type: FAT16
    • Max. data trasfer rate: 97.9 Mbits/sec
    • Average seek time: 12 msec (Read, typical)
    • External dimensions: 1 3/4"(W) x 1 1/2"(L) x 1/4"(H) (42.8 x 36.4 x 5.0 mm)
    • Weight: 0.6 oz. (16 g)
    • Power requirement: 3.3V±5%, 5V±5%
    • Power consumption: (Write)1.0W (3.3V), 1.6W (5V)
    • Operating temperature: range32 to 95°F (temperature gradient 9°F/min or less)
    • 0 to 35°C (temperature gradient 5°C/min or less)
    • Operating humidity range: 8 to 90% (no condensation)
    • Storage temperature range2: 2-40 to 158°F (temperature gradient 9°F/min or less)
    • -40 to 70°C (temperature gradient 5°C/min or less)
    • Storage humidity range: 5 to 95% (no condensation)
    • Compatible OS: Windows XP, 2000, Me
    [/url]
  2. I have had an IBM 1GB microdrive for a couple of years now - and it has always been a fine performer. It is starting to feel a little small now, and I was looking at getting a 2 or 4 GB Sony.
    I presume it will be Mac compatible (doesn't say so above). I also cannot believe that it is 10x faster than the Hitachi.
