FS: SEACAM superdome, strobes, arms...etc
Started by enricomarzico ·
  1. Everything in really good conditions, shipping worldwide, pickup possible in Italy, Milan. Prices are negotiable for multiple objects.
    - S6-S6 CABLES 110 euro EACH: perfectly working, 4 avaiable
    - SUPERDOME SD price 900 euro: good conditions, superficial marks on the very side, almost outside of the frame, unoticeable in the pictures.
    - Front PORT 120 with AR COATING 200 euro very good conditions, a small mark of the ar coating inside the port caused by the plastic of the lenses touching the glass, out of the frame and unoticeable.
    - 20mm EXTENSIONS PORT: 100 euro
    - ARMS AND CLAMP SET 650 euro: 4x400mm, 4x150mm, 6 clamps, 2 starter balls.
    - SEACAM SEAFLASH 150TTL: 1400 euro for both: perfect conditions, batteries changed recently, at 100% efficency, (200 FULL POWER FLASHES EACH)
    - Canon 1D MARKII Housing with s6 connections 300 euro
  2. Update and REBATE:
     S6-S6 CABLES 100 euro EACH: perfectly working, 4 avaiable
    - 20mm EXTENSIONS PORT: 80 euro
    - ARMS AND CLAMP SET 650 euro: 4x400mm, 4x150mm  SOLD
    - 6 CLAMPS 150 EURO
    - 2 STARTING BALLS 100 EURO
    - SEACAM SEAFLASH 150TTL: 1200 euro for both: perfect conditions, batteries changed recently, at 100% efficency, (200 FULL POWER FLASHES EACH)
    - Canon 1D MARKII Housing with s6 connections 250 euro
  3. UPDATE AND REBATE: SUPERDOME SOLD!
    - Front PORT P105  120mm with AR COATING 200 euro very good conditions, a small mark of the ar coating inside the port caused by the plastic of the lenses touching the glass, out of the frame and unoticeable.
    - 6 CLAMPS 150 EURO
    - SEACAM SEAFLASH 150TTL: 1000 euro for both: perfect conditions, batteries changed recently, at 100% efficency, (200 FULL POWER FLASHES EACH)
  4. Still avaiable 20mm extension ring??. I think it’s compatible with Seacam 5dm2 housing…
  5. Hi Luis, yes is still avaiable, and it's compatible with the Seacam 5DMK2 housing.
  6.
    UPDATE AND REBATE
    S6-S6 CABLES 80 euro EACH: perfectly working, 4 avaiable
    - Front PORT P105  120mm with AR COATING 200 euro very good conditions, a small mark of the ar coating inside the port caused by the plastic of the lenses touching the glass, out of the frame and unoticeable. 130 euro
    - 6 CLAMPS 120 EURO
    - 2 STARTING BALLS 90 EURO
    - Canon 1D MARKII Housing with s6 connections 200 euro
    I sent you a PM.
