DPP 4 is horrible slow, what to use?
Started by stillviking ·
  1. Hello wet buddys,
    I recently moved from DSLR to the mirrorless R.
    I have always used DPP 3 and it was excellent and fast. It turns out that DPP 4 is so slow to open the new .CR3 files making it impossible to make the selection of photos from a shooting session (check photos when similar (sharp, focus, etc) to delete, etc.).
    What do you recommend for a quick opening of photos for selection / comparison between them before starting really editing in Lightroom?
    I can't believe how Canon did DPP4 so much worse than DPP3!
    Share your experience!
  2. I use ACDSee ... but you will have to check it has support for the latest Canon raw files
  3. The best RAW viewer (no edit, just viewer) is witzhout a doubt Fast Raw Viewer
    Many options. Super fast, and achieve the goal you described (i have the same)
    I will try it for sure, thanks!!
  5. I think DPP4 is great, maybe it depends on what machine you're running it on, and maybe there is a support issue for the 'R' files - just guessing there though.
    That said, I always use Photo Mechanic to view the files before import - a great and really fast program that gets rid of the rubbish files prior to downloading them to your RAW converter
    Mike
    Mike
    Photo Mechanic looks amazing, will give it a try!
  7. Look at Breezebrowser Pro, it is very fast for reviewing and you can do a fully functional 30 day trial. I use it and have the preview quality set to highest.  It is purely a reviewing program - I wouldn't use it for raw conversions.  It's Windows only
    I will have a second vote for Fast Raw Viewer.  I just finished my trial and I will be buying the software with a smile next time I need to sue it.
