Panasonic GH6 handling and impressions
Started by Interceptor121 ·
  1. The lag of the HDMI can be reduced if you use only a  monitor with a few tricks and it only
    What do you mean? Could I use my 1080p monitor?
  2. The lag of the HDMI can be reduced if you use only a  monitor with a few tricks and it only
    The monitor outputs are still 1080 4K etc
  3. Ah ok. Bu IIRC currently all monitors have a 1080p panel except maybe one model. So I shouldn't be a problem.
  4. Ah ok. Bu IIRC currently all monitors have a 1080p panel except maybe one model. So I shouldn't be a problem.
    I know but the camera can output 8k actually
  5. My camera should arrive on Monday will keep everyone posted
  6. Massimo, if you still have  the GH6 with you, one question:
    Does the HDMI output work with the open gate mode?
    I discovered that on GH5, on open gate, when you press record button, hdmi out is disabled, so bye bye monitor!
    Works fine with Atomos Shinobi and Ninja V that also have a desqueeze function
