FS: Watershot UW Housing & Canon XSi with 2 lenses ($1200)
Started by clarktheshark ·
  1. Watershot housing (galvanized aluminum) with flat glass port, all o rings, extra o rings, protective port caps
    Canon XSi Rebel (450/500 D) with 2 batteries
    Kit Canon 18-55mm 3.5-5.6 lens with zoom gear
    Canon 60mm macro lens
    asking $1200 OBO
    This is a perfect starter or back up system with 2 lenses compatible the flat glass port. There is a CR2032 powered leak detector inside the housing. 2 fiber optic ports for strobe attachment. All gears in excellent working order. Some minor cosmetic wear on the housing, but everything works perfectly. I have upgraded so no longer need this on the shelf. I am willing to provide instructions and advice if interested.
    Edited by clarktheshark
