About the Ninja V
Started by John Doe II ·
About the Ninja V
  1. Looking at buying a Ninja V monitor/recorder.
    This recorder has a hdmi IN and OUT. If i were to connect another Ninja V to the hdmi OUT of the first Ninja V, does this mean I could trigger start/stop record from the second daisy chained monitor?
    Dive and See have cables for transmitting hdmi over 30 to 50m (maybe more but not sure what is current with them - they have so many different cables). By using a hdmi connection to another monitor would allow one to see the live view in real time instead of 1/2fps over ethernet.
    If all of the above is true then it would seem the Nauti Cam Ninja V housing is preferable as it is has two bulkheads on it. The Seacam version only has the one bulkhead (although Seacam may be able to drill another bulk head?).
    I am a bit torn on which way to go here. I have a a Nauticam C200 housing and Seacam 1DC housing. I would like to tether both systems (at different times) to remotely monitor and record from topside to a depth of around 50m.
    Any pointers?
