For the past year I've been using my Fujifilm XT-3 in a Nauticam NA-XT3 housing, predominantly with the 15-45mm lens and WWL-C, and occasionally with a flat port used with my 80mm macro. I've been pretty happy with my results, with the limiting factor still my skill rather than my equipment.
The 15-45/WWL-C combination works pretty well, except that there is vignetting wider than 18mm. Not too much of an issue given the usual location conditions. I have planned a trip to clearer waters later this year which should provide more opportunity for wider angle photography, so I'm considering purchasing the 180mm dome and use the 10-24mm zoom. I could also use my 18-55mm with the 180mm dome.
When I originally reached out to Nauticam for their advice, the response was that the 15-45mm would be "far sharper combination than the 18-55mm and 10-24mm behind the 180mm dome"
Any opinions?
