AO Cooler Bag with Camera Cube
Started by Pomacentridae ·
  1. Might be of interest to people. My setup to transport my camera kit.
    I am using an AO Cooler with a Camera Cube insert when i travel. The size is carryon compliant. I am using the 24 Can size but even the 36 can size is carryon compliant.
    On arriving in the hotel or cabin i remove the camera cube and leave it in the hotel. The camera cube acts as an organizer to hold all my dry accessories like chargers, etc. Assembled camera goes into the AO Cooler which acts as my boat bag and personal rinse tank.
  2. I use the same method
    at home it's in a dry sealed plastic box and when I'm out with it I use a big cooler for the rig and in the pockets I put all of the cables and the lens cover etc.
    it helps to protect the rig while on the boat and after the dive I just fill it with fresh water and let the rig sit in it until I finish washing all of the diving gear
  3. What strobes are you using?
  4. @Dann-Oh I am using the Inon Z330 Type 1.
