Nauticam 230mm Glass Dome (plus some other items)
Started by djmcmath ·
  1. I'm shifting from the 16-35mm rig to a different lens setup and letting go of all of the gear specific to that lens.  All of this gear is used.
    $1200 -- Nauticam 230mm optical glass fisheye dome port #NA-18812.  The plastic hood shows quite a bit of wear, but the glass is clean.  Or, well, as clean as I can get it -- the dome surface attracts dust like a cat that's been rubbed on a shag carpet.  Comes with neoprene cover (much newer than the port itself, I kept losing the covers...) and the case it comes in.
    $450 -- Nauticam N100 to N120 35.5mm Port Adaptor II #NA-37305.  Note that this is the one designed specifically for the NA-A7IV, different than the other N100-N120 adaptor.  Moving parts function cleanly, lock/unlock and focus move smoothly.  Condition is definitely pretty good, but not perfect.
    $350 - Nauticam Extension Tube 60 with lock (for N120) #NA-21160.  Condition is great; o-ring is clean, lock functions perfectly.
    $200 -- Nauticam SE1635-Z Zoom Gear for Sony Vario-Tessar T FE 16-35mm F4 ZA OSS Lens #na-37145.  Lived inside the housing, rarely saw daylight.  Complete with the little rubber shims.  Label is mysteriously worn.
    $200 -  Nauticam SE1635-F Focus Gear for Sony Vario-Tessar T FE 16-35mm F4 ZA OSS Lens #na-37146.  Installed once, found to be too much of a hassle, and just left it off.  Almost new.
  2. im interested in the dome, still available ?
    Yes, sent you a PM to follow-up.  :)
  4. Some additional pictures of the dome port -- I can definitely move most of the dust around, but there's one spot that doesn't change.  To make sure it's visible to everyone, I've highlighted it in red in this first photo.  It's visible in several others, but tough to see if you don't know what you're looking for.
    DSC09195-Edit.thumb.jpg.f031e10173a818fc6d7f0ad8a6e78270.jpgDSC09194.thumb.jpg.4405179cb9586e14767a79dd782f66af.jpgDSC09193.thumb.jpg.52c3a57e24beb11ef1d43bac26ac0efc.jpgDSC09192.thumb.jpg.099d675d9b4b172ea0790d81be3a95f9.jpg
  5. Did the dome get sold?
    Nope, not yet.  I've sent you a PM.
  7. Dome is sold.
    Still remaining:
    N100-N120 adapter NA37305 -- $450
    Extension tube 60 NA21160 - $350
    Zoom and focus gears for Sony 16-35mm lens -- $200 ea
  8. Gears are sold.
    Remaining:
    N100-N120 adapter NA37305 -- $450.
    Extension tube 60 NA21160 -- $350.
