1DsMK II in Seacam 1Ds MK1housing?
Started by f10ab1b ·
  1. 1DsMK II in Seacam 1Ds MK1housing?
    Hi,
    I remember reading in this forum a month or two ago that the 1DMKII works in the 1D/1Ds MK1 Seacam housing, but without the use of the 3 buttons below the LCDs.
    So, I was wondering if anyone knows if the 1DsMKII is the exact same body as the 1DMKII? ie: will a 1DsMKII fit in a Seacam 1Ds MK1 housing and work properly except the 3 buttons below the LCDs?
    Many thanks to anyone who can help with this information!
  2. Re: 1DsMK II in Seacam 1Ds MK1housing?
    Yes, the 1DsMKII is exactly the same body as the 1DMKII. I have both and they can be used interchangeably in my Seacam 1DMKII housing.
    Now, your next question requires a bit more explanation: "will a 1DsMKII (camera) fit in a Seacam 1Ds housing and work properly except the 3 buttons below the LCDs?".
    1. The new housing has a much improved lever to accommodate the * button when using CF 4-1 (see below). All things considered, the second generation MKII housing is preferable. Whether you have a 1Ds or a MKII/1DsMKII, if you don't already have a housing, buy the MKII housing.
    It is part of the new machining and can not be retrofit to an old housing. If I had to trade-off the buttons at the bottom of the LCD (when using a 1Ds camera) and the * functionality, I'd opt for the * and use the MKII housing.
    2. For those with a 1Ds camera wanting to use the new MKII housing, it can easily be fit to that camera at the factory. Primarily it is the two forked levers at the top of the camera that need to be bent according to which camera is inserted.
    3. For those with a 1Ds housing wishing to use the new 1DsMKII camera (which I assume is the point of your inquiry), we can fine tune it at our studio by replacing the forked levers and doing fine adjustments on a few other controls (on/off, main wheel). As there are small differences between each camera, we prefer to have your housing and camera. However, we can tune to one of my MKII cameras and it will very likely work with yours as well.
    So, the short answer is for MKII/1DsMKII, assume they are identical.
    1Ds is not identical to MKII but close enough to make it work. The thing we don't want to do is change the camera platform so we are always certain to maintain the exact optical center , just as it came from the factory. This is very precise positioning and wide angle performance requires it be unaltered.
  3. Hi Stephen... thanks for the fast reply and the detailed information! Yes, you are correct that I have a 1Ds Seacam housing and I want to use it with a 1Ds MKII camera. I see your point regarding the new design for the * button and would love to have it. Unfortunately, I can't justify an all new housing right now. I just sent you a PM with my email address and some questions about the potential modifications.
