FS: Underwater Video Lights 15.000 Lumen; 2 pieces + Control unit
Started by nihrzenjak ·
  1. For sale is TOP underwater lighting with a control unit.
    All 100% correct, used for one underwater film.
    The lighting is top, thanks to the high CRI factor the color response is excellent.
    Using lighting thanks to the control unit is very easy. Lighting can also be used as a flash.
    The lamps are located in Germany, can be sent within the EU.
    PRISE PER SET = 1.400 EUR
    X-LIGHT M15000 Lumen Video Lamp & Flash M15000 underwater high-CRI photo video light with flash function
    The X-LIGHT M15000 is a professional high-end CRI underwater video light that is equipped with 15000 lumens. The lamp uses a COB LED, which significantly improves the color rendering index (CCK 5600K, CRI=Ra96, TCLI:97, R9:94) to be very close to sunlight. No multi shadow effect. Built-in battery status indicator. The X-LIGHT M15000 is a hybrid! Means: The underwater video light is also a flash! The unit can be connected to the underwater housing using standard fiber optic cables and once the strobe function is switched on it behaves like a regular underwater strobe. In practical operation, the lamp can be set to e.g. 10% power. So you can see what you are doing, the camera can focus and as soon as the target is focused and the shutter button is pressed, the light flashes with the power you have selected (up to 15,000 lumens! Rotary knob + push button for easy one-handed operation. Built-in infrared signal communication interface, optional remote control available. Comes with a YS mount and a ball mount that easily mounts to your camera arm system. Practical detail: the battery can be inserted upside down into the lamp and is therefore safely stowed away and cannot be accidentally switched on. This professional underwater video light (and the M8000) is currently one of the best video lights on the market.
    Product Specifications:
    • Beam angle 130°
    • color temperature / Color rendering index 5600K / Ra96 / TCLI:97 / R9:94
    • Total luminous flux/burning time wide-angle light: 15000lm (10 brightness levels) @50min.
    • battery status indicator (80%~100%) Blue (15%~80%) Green (1%~15%) Red (1% or less) Flashing red
    • Control methods: rotary knob + mode button
    • Power supply: Rechargeable Li-ion battery, 6800mAh 100Whr
    • Max diving depth: 100m, IPX8 (JIS protection class 8)
    • Dimensions: Max. ø73mm x 205mm (excluding protrusions)
    • Weight: 960g on land, 480g underwater
    • Materials: Corrosion-resistant aluminum alloy
    • Included Items M15000 Hybrid Underwater Video/Flash unit 1 x Li-ion Battery 1 * Power Adapter 1 x YS Adapter 1 * Ball Adapter 2 x spare O-rings 1 x soft case 1 * Dome Neoprene Cover
    New price: 790 EUR - one Lamp
    X-LIGHT Remote Control Unit RC-02 Remote control for video lights with RC function of the M8000/M15000/M6000 series. Single or dual operation. Works with up to 2 standard slave cables (Sea&Sea connectors) Brightness control / separate / dimming. Standby mode. It is mounted on the standard T-Base Plate or with an optional adapter plate
    New price: 75 EUR
  2. Bump...new price 1300 EUR
